4th gen 5 speed, i'm in a pinch
Old Dec 15, 2004 | 06:54 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Will the 4th gen V6 T5's work in the place of my NWC T5 in my 87 GTA? I just blew my transmission and need to get back on the road quick. if it will I found a T5 out of a 1996 camaro with 48,000 miles for $150 bucks. Thanks for the help
Old Dec 15, 2004 | 12:40 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
If your current engine is a V8, which it looks to be the case, than the V6 T-5 will not work. I asked about this a few months back and the reason given is that the bellhousing is completely different to mate up to a V6 than a V8. The general consensus was that it could be modified to work, but it wasn't worth the money, time and effort.
Old Dec 15, 2004 | 12:43 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
The v6 t5 will bolt up to a v8 bellhousing. The fourthgen WC T-5's are the exact same ones as the thirdgens. I know because I had my brother in laws 95 3.4's WC right next to my 91 WC. When you run a V6 T-5, you need to run a S10 Clutch, its the only one that has a large diameter and the same spline count for the v6 t-5.
Old Dec 15, 2004 | 12:50 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
my mistake, I came back to this thread because i suddenly remembered that your car already had a 5-speed so you have the required bellhousing. I'll shut up now and let more qualified individuals step in
Old Dec 15, 2004 | 02:41 PM
pasky's Avatar
We all make mistakes bud, were all only trying to help after all so any opinion is usually welcomed. I've been corrected quite a few times on this site.
Old Dec 15, 2004 | 02:52 PM
battman's Avatar
Thanks pasky thats great news. as far as the clutch goes, i would asume the clutch is from a 4.3 S-10? if so what year range?
Old Dec 15, 2004 | 03:14 PM
pasky's Avatar
Im not quite sure, you want the one with the 11" diameter or its a 10 3/4 diameter. Basically the biggest clutch they got for the S10. Yes that would be the correct motor, the 4.3.
Old Dec 15, 2004 | 08:51 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Later V6 T5s have the "ford" bellhousing to trans. pattern and do not bolt up to the V8 bellhousing. I am not sure what year this happened, or whether it was done with the 3800 powered f-bodies.
Old Dec 15, 2004 | 09:47 PM
battman's Avatar
from the looks of this ebay link, it looks if the 99 T5 will work to. What do you guys think?
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
Old Dec 15, 2004 | 09:50 PM
jmd's Avatar
jmd
Nope. Read my post.
Old Dec 15, 2004 | 10:16 PM
pasky's Avatar
Must be the 3800's only, the 3.4's were the same exact t-5's.
cam-mike
Aug 24, 2015 07:23 AM
Kaweh
Aug 9, 2015 02:54 PM
Amillionoh7
Aug 7, 2015 01:24 PM
