t5 shifter interchangability
Old Dec 15, 2004 | 11:55 AM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
first off is interchangability a word????? now to my question ive done a lot of searchin and i cant find a thing. will a t5 mustang stifter, the hurst comp plus, bolt up and work on my WC T5. it sould right ? i hope. let me kno cause i could get a deal on one but i gotta kno soon. thanx guys
matt
Old Dec 15, 2004 | 05:07 PM
common someones gotta kno
Old Dec 15, 2004 | 05:11 PM
KiLLJ0Y
Guest
Posts: n/a
the shifter plate should match.. but the sticks wont.. the T-5 sits off center towards the driver at about the 11 O'clock position.. thats why if you look at the stick its bent.
i dont know how they install the mustang T-5, but the bolt pattern should be the same, but the stick is going to be different, depending on transmission mounting.
Old Dec 15, 2004 | 06:26 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the shifte plat will not match (i know)
Old Dec 15, 2004 | 06:57 PM
thanx alot for the info. heres what im tring to get at. can i bolt up and use a mustang short shifer. i could change the stick if i have to. i just wanna kno if it will bolt up and shift my tranny
Old Dec 15, 2004 | 09:03 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
why would you want to use one from a mustang. just get one for a f-body call it good. it sounds like a lot more work than it is worth.
Old Dec 15, 2004 | 09:08 PM
its not that i want one from a mustang but my friend is puttin a TKO in his foxbody and cant reuse his shifter. i planned on buyin one soon but if his will work it would save me some cash.
Old Dec 15, 2004 | 10:02 PM
ok i understand now. i was under the impression that you wanted to buy it because of price differences. let me know if it works. i have a guy that will give me one if it will work for me. i just didn't want to ask the question you asked fearing the feedback i might get by wanting to use a ford part.
Old Dec 15, 2004 | 10:10 PM
yea ford is yucky eeewwww
Old Dec 16, 2004 | 01:09 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
besides the price u see alot more shifters for mustang t5s and for camaros
Old Dec 16, 2004 | 07:35 PM
Engine: ls1, LB9
I guess you guys don't understand but, go ahead and try to bolt it to the trans. I bet the bolts won't even come close the threaded holes. (I have worked on many fox body cars and many many f-bodys) it won't work unless you really redo things
Old Dec 18, 2004 | 11:20 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
IT WONT WORK!!!!!!
Old Dec 18, 2004 | 12:08 PM
jocww's Avatar
can u redrill holes or use the camaro plate and the mustang stick
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
