B&M Ratchet Shifter Problems
Old Dec 9, 2004 | 01:29 PM
305Camaro84's Avatar
Car: 1894 Camaro Berlinetta 305 auto
Engine: 305 LG4
Transmission: TH 700 R4
my B&M console megashifter is being retarded. ok its kinda like a sticking problem. when you take it out of park you have to slam it down and somehow get it inbetween nuetral and drive and then give it a good wack and it usualy goes into gear. basically it sticks and is verry hard and mostly annoying to use. could this be sometiing in the racheting device that is used or some kind of linkage. and does anyone know how to fix it
Old Dec 9, 2004 | 03:14 PM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
I would dissasemble the unit and check for anything out of the ordinary. I could also be bindage in your shifter linkage to the tranny.
Old Dec 9, 2004 | 09:40 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
you improperly adjusted your shift cable. go back and read the instructions and and correct yourself.
Old Dec 15, 2004 | 12:47 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
yah i agree about the checking your mounting and adjustments up by the transmission....i have a megashifter and i noticed problems with it not working properly and all i had to do was go back and adjust the tranny adjustments and it was fine.....good luck!
Old Dec 18, 2004 | 09:14 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
just got a used one and don't have the manual to intal it.Does anyone has it?
Old Dec 18, 2004 | 09:40 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
i have a manual for the megashifter....i can scan it tonight after work for ya....its kinda dirty but i think it will work for ya...
Old Dec 18, 2004 | 09:42 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
thanks matt
Old Dec 18, 2004 | 02:37 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
no problem....check your e-mail i made it into a windows word file.....good luck!
BewleyBizzIROC
Feb 3, 2020 09:52 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
