Will a 9" work with stock torque arm?
Old Dec 19, 2004 | 03:19 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I'm going to buy a brand new 9" rear end with 4.11's in it. The guy bought it for his LT1/T56 '89 GTA, but he said it wouldn't fit with the Spohn Torque arm. I've got a stock torque arm on my '88 T/A. Will this rear end fit without problems?
Old Dec 19, 2004 | 09:56 PM
EvilCartman's Avatar
Car: '82 Z28
Why wouldn't it work? Sure as hell works with my 9"
Old Dec 19, 2004 | 11:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its designed to fit into a 4gthen, then it should also fit into a 3rdgen with minimal fuss.
Old Dec 19, 2004 | 11:18 PM
86camedcamaro's Avatar
Transmission: 350 turbo
EvilCartman
hey what company makes that rear of yours? looks pretty good.
Old Dec 20, 2004 | 01:30 AM
Car: '82 Z28
The rear is from Currie and the 3rd member was bought local from a buddy.
Old Dec 25, 2004 | 10:35 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Well I'm getting a Currie 9" Rear. The guy swears it'll fit the stock torque arm..it just didn't fit his Spohn Torque Arm. Will a Currie 9" rear fit the stock torque arm? I just wanna make very sure.
Old Dec 26, 2004 | 05:17 AM
Car: '82 Z28
I don't see why it wouldn't fit. Call up Currie and ask if you want to make sure. There was one thing I had to do though, change to the other set of holes for the torque arm. The 10 bolt used the inner set and when tried with the Currie, it pushed the arm out too far hitting the underside. Using the outer set of holes sucked the arm back in. The stock arm isn't as bulky as the Spohn one so it should fit.
Old Dec 30, 2004 | 08:32 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Ok, here's the deal. The guy who bought it for his '87 GTA, he said everything bolted up right, except for the Spohn Torque Arm. He also said that the rear will come with disk brakes, and all the related brake cables.
I've got drum on my T/A, is there anything else I'll need to put this disk 9" rear in and get it working..besides a new prop valve?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
