shift rail assembly question
Old Dec 20, 2004 | 07:39 PM
petes88ta's Avatar
Car: 88ta 305 5spd
with the cover off looking directly at the shift forks, should you be able to see the flat on the end (towards the front of the transmission) of the shift rail or should it face the inside of the cover?
Old Dec 21, 2004 | 09:08 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Not really sure what you mean. Can you post a pic?
Old Dec 22, 2004 | 06:52 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: shift rail assembly question
I understand what you're saying but I don't see why it matters. The shift pin has to go into the fork lever stuff and can only do so one way. Don't look at the flat you're looking at. Look at the forks and make sure all that is working.
Old Dec 23, 2004 | 12:13 PM
petes88ta's Avatar
Car: 88ta 305 5spd
the flat in question is circled in red on the left
Old Dec 23, 2004 | 12:38 PM
jmd's Avatar
jmd
Yes you should be able to see it. You don't have an option as to where it faces.
1992 Trans Am
May 10, 2023 07:19 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
