Engine idles on freeway with no throttle?
Old Dec 20, 2004 | 10:43 PM
87GTAspeeder's Avatar
Car: 1987 GTA :)
Engine: duh! 5.7 TPI
Transmission: Stock
My assumption is that this is something related to the transmission. It just started the other day. Doesn't do it consistantly and is with a 700r4 in an 87 GTA
When I'm on the freeway in OD if I let off the throttle the engine will drop to just above idle. Also I tried it at lower speeds and in third, if I let off the throttle at midrange RPM it will drop a bit (normal) but sometimes it will start dropping to idle then catch. I can just pick up a sound like something disengaging then re-engaging.
Any ideas/solutions before I jump into this? Thanks!
Old Dec 22, 2004 | 12:28 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
its going into neutral. dont worry your saving gas id think it might be a band or a clutch but ive never had that problem when u gas it again does it lockup right away or does it slip. if it slips then its a band or a clutch 75% chance at least
Old Dec 22, 2004 | 02:19 AM
Pro Built Automatics's Avatar
The overrun clutch and/or sprag is going away.
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
