Hit a curb....
Old Dec 29, 2004 | 12:35 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
Hit a curb....
so I junked my drivers side rear wheel, and now a clunk with a brake grind every revolution... I don't know much about this area of the car... I'm assuming an axle or wheel bearing bent?
can someone tell me what I can look for to tell what this is....
such a sad day... car is a 94 z28... I have a third gen too, so maybe you could still show sympathy, and you know, help me out please...
Old Dec 29, 2004 | 11:53 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Sounds like a bent axle. The axles arnt too hard to remove. Probably not a bad idea to replace the bearings and seals on both sides as well while your there. Im sure they could probably use it after 10+ years.
Old Dec 29, 2004 | 01:03 PM
87 L98 TA's Avatar
Car: 1987 Trans Am
Do I just need 10 bolt axles?
Any idea where I can get them, and about how much they'll cost?
Old Dec 29, 2004 | 02:03 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Just bought 'em.
Nice hi-po replacements from summit
http://store.summitracing.com/defaul...Ntt=SAG-EV10-4
Old Dec 29, 2004 | 05:40 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I think the 4th gen axles may be a different legnth then the 3rd gen ones.
Old Dec 30, 2004 | 01:03 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
hmm so I pulled the rotor, got a new one, when I had it off put the car in drive and the hub wobbles like no ones business...
I'm under the impression its a 1 piece hub and axle and I'll need to replace the whole thing....
Old Dec 31, 2004 | 12:28 AM
Car: 88 Camaro SC
Engine: SFI'd 350
yes, go out to a yard and get another axle. Make sure to get the correct one. Both the left and right axles are different lenghts.
Old Jan 3, 2005 | 11:00 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I'm really surprised the axle bent and the wheel didn't. Usually the wheel bends before the axle.
Old Jan 4, 2005 | 02:27 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
the wheel is pretty toast...
I found another wheel, and rotor... now to get the axle. ebay has a couple that are lookin good and cheap with little time left, hopefully they work out.
Where should I go for bearings?
Old Jan 4, 2005 | 09:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup; IIRC the correct Superior axle for a 4th gen is the EV10-5. The EV10-4 is the one for third gen rears. The 3rd vs 4th gen axles are about 1-11/16" or so different in length.
You can get bearings & seals at any parts store. They come with the set of the Superior axles.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
Twinn Engines
Sep 25, 2015 06:27 AM
