Transmission problems.
Old Jan 2, 2005 | 03:57 PM
GhostTransAm's Avatar
Car: 1987 GTA Trans Am
This is diffacult to explain so bear with me.
I am able to rev the engine like its in neutral in all 4 gears(I only press down the gas about 1/2 way and it jumps all the way to redline). The car moves slowly in all the gears, it moves faster in 1st. I am revving it to 4 grand in 1st and only able to move 20 mph. Anyone have any clue what is going on? Thanks.
Old Jan 2, 2005 | 04:13 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
torque converter may be down on it.. could also be the tranny slipping really bad.. how many miles are on the tranny?
Old Jan 2, 2005 | 04:31 PM
I have no idea how many miles are on the transmission because it was swapped in with a 350 from a previous owner and I don't know how many miles it has. The car itself has 160k miles on it. I didn't hear a big clunk or anything when it occured 2 days ago.
I checked the fluid levels and the ATF was brownish in color. I put some more fluid in because it was low and the tranny started to act better but not alot. It was shifting really well just 2 days ago before this happened. I was just cruising at 45 in 3rd and then the problem occured. The tranny never slipped before at all. So yes I was thinking the TC was the problem but I need someone else's input.
Old Jan 2, 2005 | 07:51 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
Try changing the filter. it might be plugged with crap and not letting enougth fluid trough.
Old Jan 2, 2005 | 08:31 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
although these 700's arent bult for 500k miles haha, probably time for a rebuild good thing they are cheap
Old Jan 2, 2005 | 08:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
yup, its doing what mine did... clutchs burned up.
get a new one.
Old Jan 3, 2005 | 01:44 PM
So I'm going to have to replace the tranny then? How long does it take?
Old Jan 3, 2005 | 02:04 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
to do the work yourself? it can be done in a day.
Old Jan 3, 2005 | 08:27 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
**** we dropped it in 45minutes....
Old Jan 4, 2005 | 03:25 PM
Ok so basically follow the what the hayes repair manual says? Good it isn't that hard then! thanks!
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Camaroguy2
Sep 22, 2015 08:22 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
