9 bolt swap
Old Jan 1, 2005 | 01:17 PM
bigjimh48's Avatar
Car: 1991RS
Engine: 305tbi
9 bolt swap
I have a 1991 RS with a 305tbi it has a 10 bolt with drum brakes. I have a chance to get a 9 bolt with posi and disc brakes. is this a good rearend or am I better off keeping my stock rearend? I have the hole doner car parked next door and this will be a freebe all I will have invested is my laber. but know nothing about these rearends and would like some advice I don't want to swap and find out this is a week rearend or hase problems.Thanks in advance for any help you can give me
Old Jan 1, 2005 | 01:48 PM
Parrydise7's Avatar
Go for it. The 9-bolt is a lot stronger than the current axle. Unfortunately, the parts for that 9-bolt are a little pricey.
DynoDon is holding a 9-bolt for me. As soon as I get some money together, my 10-bolt is history.
I wish I could find a Dana 44.
Old Jan 1, 2005 | 03:05 PM
bigjimh48's Avatar
Car: 1991RS
Engine: 305tbi
thanks for the reply. I gues I have some work to do now. Dose anybody else have any coments?
Old Jan 1, 2005 | 04:25 PM
Parrydise7's Avatar
As a noob, you may want to become familiar with the search function. This particular issue has come up before, so there is a lot of information available.
The great thing, all of that information will help you convert from drums to discs (it includes part numbers). Good luck.
Old Jan 1, 2005 | 08:12 PM
bigjimh48's Avatar
Car: 1991RS
Engine: 305tbi
the swap is done
thanks for the advice I have a compleate doner car to swap parts from so I don't need any parts thay are all thear. I have already swaped the rearend all that is left is to swap master cylinder and bleed the brakes thanks again
Old Jan 1, 2005 | 08:53 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
You don't need to swap the master cylinder, they're not any different. Just get the prop. valve (the piece under the master cyl. with the lines going to it) and swap that out. You may even be fine with your stock prop. valve.
1984HO
Mar 19, 2021 11:59 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theurge
Aug 21, 2015 12:46 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
