Vigilante TC too much?
Car: 92' RS Camaro
Hey guys,
I've got an opportunity to purchase a 3,000mi used Vigilante 9.5" 2800 Lockup TC for $400.00
My question is how will this work with my setup and is it too much?
Current Setup:
L98 Longblock (All stock heads/cam/bottom end etc...)
RPM Air Gap Intake
670 SA Holley VS (I know stupid... 650 VS cheaper we all learn
Hooker 1 5/8" Headers/Y
3" Catback
The car was originally a L03 (92). So I believe it has a 2.73 One wheel peel out back and the 700R4 is equally as Stock. How will this Torque Converter behave in this /mild/ engine??? This is not my daily, just a weekend, but if it is too much I can get a S10 converter a hell of a lot cheaper...
Also it might help if you know what my plans are.
I have completed Stage I (305 --> 350)
Stage II = AFR 195 Heads/Large Cam
Stage III = 383 Bottom End / or HT383 Shortblock
Stage IV = Conversion to DFI (Stealthram or Miniram)
And all along the way improving suspension etc...
Stage 1001 = LS7 (WOW) hehe j/k I wish...
I've got Stage I done, I'd be lucky to get Stage II even by 06 (two chillin'
) But thats the plan anyhow.
Any opinions? Pick up the Vig, or go with a S10???
Thanks!!!
Current Setup:
RPM Air Gap Intake
)Hooker 1 5/8" Headers/Y
3" Catback
) But thats the plan anyhow. Any opinions? Pick up the Vig, or go with a S10???
Thanks!!!
Car: '91 RS, F41
Transmission: WC T5
if you plan on doing all of that, then i would go ahead and buy it, and install it with stage II....you really need a set of gears to keep the converter out of its stall range all the time..
Car: 92' RS Camaro
Has anyone had experience with the S10 converters??? Only thing I'm afraid of is that after I get farther along that the 2800 will not be enough and even though I only paid $400.00 thats $400 towards the 3500 stall.
I've heard the S10 converters stall at around 2200 and new are only around 150 + core. Probably find one in the boneyard for much less....
RMK
Sep 10, 2001 07:29 AM
BuckeyeROC
Jul 13, 2001 07:50 PM
Wayquick4u
Apr 12, 2001 08:12 AM
Rob98Z
Nov 6, 2000 09:04 PM
