think i'l break it?
Old Jan 9, 2005 | 10:18 AM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
think i'l break it?
i'm rebuilding the rear end out of my 84 camaro. i'm putting in a posi carrier from a 97 z28, 28 spline axles, and probably 4.10 gears. it will be behind a vortec headed 350 with a fairly decent cam(probably a crane 282). i'm not going to run drag radials or slicks, probably something like dunlop sp5000 245/50-16s. how do you think it will live?
my brother's 97 camaro with a few things done to it had some nasty wheel hop and a 6 speed and never broke it, so i don't see why i would with an auto and not much more power
Old Jan 9, 2005 | 10:57 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
that 10 bolt built that way will be just fine...even helps a lot more that you won't be running slicks or drag radials.
Old Jan 9, 2005 | 10:59 AM
TexasLT1's Avatar
Car: '92 RS
if you're just running street tires, don't worry about it, you won't have any problems as those Dunlop's are probably not sticky enough to get any good traction, especially with 4.10 gears. Now if you start running slicks, then yeah, its on borrowed time.
Old Jan 9, 2005 | 11:01 AM
rjmcgee's Avatar
Replace the crush sleeve with a solid bearing spacer.
Old Jan 9, 2005 | 11:08 AM
ede's Avatar
ede
yeah i think it'll break, or could be broken
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
