t-5 AIR and smog
Old Jan 9, 2005 | 04:19 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
t-5 AIR and smog
If you are swapping a t5 into a v6 700r4 car that does not have an AIR system, for smog purposes in Cali are you then required to have an AIR system, or are you exempt because it wasnt stock on your exact car?
Old Jan 9, 2005 | 04:26 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I can't say on the specifics of the rules but, since your did not have a 5-speed from day one it falls into a real iffy area. your best bet is to not even metion it to them at all.
what is that comic you have going? you make that?
Old Jan 9, 2005 | 08:52 PM
Naft's Avatar
heh, i wish i made it, its those comics are pure genius.
www.whiteninjacomics.com if you like random funniness.
Yeah, im hoping that they just wont realize that a manual fbody has it when an auto doesnt.
Why is that, anyway? Is there some reason for the autos to not have it?
Hell, i dont think ill be passing smog any time soon either way, so w/e.
Old Jan 10, 2005 | 11:37 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I agree that I wouldn't mention it, but technically the emissions requirements are linked to the engine, not the transmission, so if the engine didn't have it originaly they can't make you retrofit it. I would just run silent, run deep on that one.
BTW, if your Scout has the original motor it's a 304, not a 305. Those a cool trucks,and the IH engines are tough as nails.
Old Jan 11, 2005 | 08:11 PM
Naft's Avatar
ok, sounds good.
huh, could have sworn the carb rebuild kit said IH 305, but then again that was a few months ago. They are cool trucks for sure.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Formula_88AE
Sep 3, 2015 01:47 PM
