need help with my t-5
Old Jan 9, 2005 | 04:37 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
i took the tranny out, and i need to open it up. i figured i could open it up from the top. i took the screws out but the top is not coming off. how do i get the top off so i can look inside the tranny. i need to open it up to see if there anything visually wrong with second gear. it makes noises.
Old Jan 9, 2005 | 06:04 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you need to knock out the roll pin located on the shaft (little hole on the block of metal the shifters ball end sits in)
Old Jan 10, 2005 | 11:43 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Did you take the tailshaft housing off yet? Everything is tied togther in a T5 because of the internal rail shifter. You've got to take the shifter off, then drive the roll pin out of the shifter detent (the thing that the ball on the bottom of the shifter rides in). Then remove the detent, but be careful not to lose the ball and spring that sit inside it. Once the detent is removed unbolt the tailshaft housing and remove it too. Then the top cover with the shift mechanism will just lift right off.
Old Jan 10, 2005 | 08:36 PM
Engine: ls1, LB9
well, slid off sideways (to the right) then strait up
Old Jan 11, 2005 | 09:17 AM
Yeah, that's true. You've got to clear the case to get the forks out.
Old Jan 19, 2005 | 01:47 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
well guys i took it to a specialist. he looked at it and couldnt find anything wrong with it. the only thing he said was that i could put new synchros in. now im stumped. when the tranny was in the car. it would make a noise in second gear but not in any other gears. im taking it to another specialst to get a second opinion. if you guys have any suggestions please let me now. hate hearing noises that dont sound good. oh and the car would drive smoothly no bucking or anything.
Old Jan 19, 2005 | 01:53 PM
If it shifts fine then I wouldn't mess with the synchros. If it's just 2nd gear the only thing I can think of that's second gear specific is there is a small cagged needle bearing inside the gear between the bore in the gear and the mainshaft. If that's worn out it could be causign your problem. Why that bearing would go and no others is anyones guess. If the countershaft bearings were bad you'd hear the noise in every gear. If a sychro was bad there'd be a noise in 1st gear too. That's about all I can think of without actually seeing the trans.
Old Jan 19, 2005 | 01:56 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
thanks tkoperformance ill relay that info to the guy thats working on my trans and see what he finds.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
