delete
thanks
thanks
ttt
383backinblack
close
the gear ratio wont make much of a difference.
the entire axle is weak, i've snapped them off before, the differential itself is usually a weak point
and the ring gear itself, only being 7.5 inches, is pretty weak
snapped what off ? how ? when ?
what ratios have you busted so far ?
ok, thats cool, but im still gonna ask;
so what breaks in these axles most commonly ?
if someone has broken one then what ratio was it ?
what broke ? and how was car driven ?
thats alll i want to know
maybe no one has ever really broken a 10 bolt and its all fable stories
thanks
thanks
ok
:P
anyone ever had one break fr no reason, IE not hotrodding, or driving like you stole it, or burning rubber, or 'hard' launching, etc., ?
thanks
:P
thanks
383backinblack
close
Quote:
Originally posted by Fast68
ok
:P
thanks
yes they break all the time, and the ratio means nothing, all the gears are the same strength.......WEAKOriginally posted by Fast68
ok
:P
thanks
383backinblack
close
thanks
axles snap, ring gears break, teeth come off, bearings go, differentials snap, pinions break etc etc etc.Originally posted by Fast68
thanks
i have 3 broken ones in the yard here
I broke a carrier in half once...
Twisted axles and stripped teeth are the other most common things
i just want ot ask for the heck of it anyways:
anyone have a 3.42 axle break ? other than shafts or carrier ?
thanks
thanks
383backinblack
close
thanks
wow your really not getting it.Originally posted by Fast68
thanks
YES they all break.....the gear ratio has nothing to do with how strong the rear end is
it doesnt matter....2.73, 2.89,3.23,3.55,3.42,3.73,4.10 etc etc etc
they all break just the same, doesnt mean anything
well since no one has any specific examples of a blown up 10 bolt third gen axle i have to say that i dont believe these axles commonly break and that they are pretty strong overall and that i have nothing to worry about
i really have never seen any 7.5 or 7.625 axle blow up
the only case that i can say i saw a failed 7.5 was under a 79 caprice i had once, it was 2.41 ratio, the axle tube housings came loose from the center housing, so the axle was bowed downwards in middle and would scrape drums on backing plates when you took turns
but had nothing to do with weakness or failure of internal parts, it was fine inside still,
i swapped another axle under it
fixed
thanks
fixed
thanks
383backinblack
close
fixed
thanks
bwahahahhaahahha.....either your being a douche on purpose here, or you are the dumbest person that ever turned a wrench on a car.Originally posted by Fast68
fixed
thanks
i just gave you specific examples.....there are several people on this board that have seen the twisted splined ends that snapped off the axles in my 10 bolt.
another one i shattered the ring gear, and a guy just told you he broke a carrier in half.
what kind of specific example did you have in mind? a scanning electron micrograph of broken parts?
since you dont belive that these rear ends are junk, then i supposed everyone who switched to a 12 bolt, a 9 inch, or a 9 bolt because they snapped their 10 bolt is a moron
if you've never seen a blown up 10 bolt there are several possible explanations.
1) you don't know anything about cars
2) you haven't been around f-body's for any serious length of time
3) you've never tried to put any power through a 10 bolt
4) you're a complete idiot
383backinblack
close
Quote:
Originally posted by rjmcgee
Hey go easy on him, I think he's 9 years old.
And retarded.
sorry i couldnt help it, this is worse than all the "t5's are a good racing transmission" threadsOriginally posted by rjmcgee
And retarded.
lol
thanks for compliments
very appreciated
some ppl need to grow up,
really
you know who im talking about
thanks for all the great info, you guys really know what a message forum is all about and for
really..
very appreciated
really
really..
383backinblack
close
lol
very appreciated
really
really..
ya its to glean information from people who know what they're talking about......which you asked for, received and then chose to ignore.Originally posted by Fast68
lol
very appreciated
really
really..
you need to grow up and learn something, you have no idea what your talking about
They break. Your chances of breaking one driving normal are low but it can happen. Same as your chances for hitting the powerball, it can happen but probably wont.
Mine has held up fine. I run 3.73's and an auburn posi. I have many 1.62-1.64 60' times on slicks launching on N2O. People tell me that they break all the time but I have yet to break mine. The car runs 6.90's in the 1/8th mile. Equivalant to about 10.80's in the 1.4 mile. Also, I have a 6speed 4th gen that I have put slicks on at the track and have dumped the clutch right off the rev limiter. I'm not saying that they won't break but I have had great luck I guess.
383backinblack
close
Quote:
i snapped the splined ends of the axles off inside the carrier launching like that with a 10 boltOriginally posted by 94-6spd
girdled and all
