Bad clunk when I get on the gas
Old Dec 11, 2004 | 05:55 PM
Schizo995's Avatar
Car: 1990 Camaro RS
Engine: 90 Caprice 5.7
Transmission: 700R4 Auto
Ive seen stuff about the rear clunkin around every rotation but mine isnt like that. If I stomp or just get on it enough to get out in traffic it feels likethe rear is going to rip out of the car. I was thinking the universles mite be the problem, but it seems to be a little to bad to be them. Is my rear going to burst into flames? Ive been plannnin on buying an axle with new gears anyway, 373 or 411. Any input on the rear or my axle search would be greatly apprieciated
Old Dec 11, 2004 | 06:08 PM
EvilCartman's Avatar
Car: '82 Z28
Trans mount or torque arm mount. Get under the car and try to lift the transmission tail to see if the mount seperates. Also give a tug on the torque arm to see if it moves around. Of course, make sure the car is secure before doing any of that.
Old Dec 11, 2004 | 06:16 PM
Schizo995's Avatar
Car: 1990 Camaro RS
So the clunk isnt rear related ? It could be a simple group of lose bolts?
Old Dec 11, 2004 | 06:35 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
Id check the tranny mount i borke 3 of them on my 89 in 4 months thery are easy to check and just to make sure its nto a simple $8 part before you replace a $800 dollar part thinkin thats it. Gm had a very bad design on the tranny mount and they are known to break
Kevin
Old Dec 12, 2004 | 11:14 AM
Schizo995's Avatar
Car: 1990 Camaro RS
Kevin
Alright im going to check that today. But I still wana look into getting posi, which gears do you suggest?
Old Dec 12, 2004 | 06:18 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
My vote is on the Trans Mount...
Old Dec 12, 2004 | 08:08 PM
Car: 87 Formula
Engine: 350 tpi
whats the setup that your runnin wheres your motor redline?
Old Dec 13, 2004 | 02:41 PM
Schizo995's Avatar
Car: 1990 Camaro RS
Ok, assuming it is one of the trans mounts, how would I check/repair that?
Old Dec 14, 2004 | 12:24 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
To quote myself (we do this thread every few weeks around here):
Checking the trans mount is easy.
1. Get the car off the ground. I like Rhino Ramps for this kind of work.
2. Remove the single nut holding the trans mount to the crossmember.
3. Place your jack under the transmission pan.
4. Using a large block of wood to distruibute the force of the jack, gently start lifting the transmission.
5. Once the weight is off of the trans mount, you should be able to see large cracks in the rubber bushing. Pieces of this may fall out. If this is not the case, you are now two bolts and 5 minutes away from a full R&R of the transmission mount anyway, so:
6. Get off your cheap, lazy butt and call Summit for the ES poly mount.
7. Install new poly mount, lower car and enjoy new, tighter feeling driveline.
Old Jan 13, 2005 | 03:22 PM
thecoolone's Avatar
Car: 89 GTA
Is it ok to NOT use a torque wrench on the tranny mount bolts?
Don't have one.
Old Jan 19, 2005 | 11:15 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Don't have one.
If there's an AutoZone near you, they should have one you can rent. They only charge a refundable deposit for it, too.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Bradsaundry
Aug 12, 2015 12:34 AM
BlackBoulder
Aug 11, 2015 11:15 PM
