Best gear for TBI camaro with 27 in tall tire (255/60/15)
Old Jan 11, 2005 | 12:52 AM
alli89's Avatar
Car: 89 Camaro RS
Engine: LO3
3.42 or 3.73?
Old Jan 11, 2005 | 12:56 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
need more info.
have a dyno graph, how about your trap speeds, is drag racing the cars only use, is gas milage a concern.
I'm running 3.42's currently, BUT my car see's alot of other uses, one of which is auto-x, and shifting to 3rd all the time, sucks for auto-x use. that is one of the reasons i went with 3.42's. Are you limited to just hose two ratio's for some reason?
Old Jan 11, 2005 | 01:11 AM
alli89's Avatar
Car: 89 Camaro RS
Engine: LO3
Originally posted by Dewey316
need more info.
I don't have a dyno graph and I have yet to go to the track. gas mileage is not a concern.
the reason i asked is becuase lots of people run 3.42 on their lo3s but most never tell what size tire they were running. I'm assuiming they're running stock size which is NOT 27" tall so i figured that if i run a steeper gear like 3.73 it would make up for the extra diameter (1 or 2 inched taller that stock I think).
the engine is stock with a few bolt on and it run pretty strong but it needs more gear than 2.73s!!
Old Jan 11, 2005 | 10:59 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Moved
Old Jan 11, 2005 | 11:49 AM
Dewey316's Avatar
Car: 1990 Camaro RS
If gas milage is not a concern, and it is used mostly for drag racing.
I would go with the 3.73's. With the taller tires, 4.11's might also be a nice option, but you didn't list that in your original post.
Old Jan 12, 2005 | 03:06 PM
alli89's Avatar
Car: 89 Camaro RS
Engine: LO3
thank you
Old Jan 14, 2005 | 12:58 AM
daddy33's Avatar
Car: '85 Camaro
if you go to richmond gears web site they have a calculation chart to show you which is the best gears to run for the 1/4
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
mizz0313
Aug 12, 2015 06:45 AM
