ford 9" rear
Old Jan 15, 2005 | 05:18 PM
matt84z28's Avatar
Car: 1984 Camaro Z28
Engine: Turbo V6
Transmission: 200r4
ford 9" rear
who has the best price on a conversion kit for an 84 z28. i gotta get rid of the 7.5 was thinkin a ford 9"?
Old Jan 15, 2005 | 06:04 PM
brutalform's Avatar
IMO the "only" way to go, is to have a unit built by either Currie, or Moser.
Old Jan 15, 2005 | 07:53 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
no matter what axle model you decide upon, you have to hope that its not too wide, or youll have to buy custom shafts,a nd cut down axle tubes length and weld flanged back on them
if you have a welder and can use it then you can do this very easily
good luck
Old Jan 15, 2005 | 10:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Buy the housing with axles from Currie or Moser. Buy a center section with the gear ratio you want locally. Cheap, cheap is to use an open carrier but buy a limited slip or locker carrier locally. Once you have the housing with axles, the rest can be purchased locally for a lot less money than in a package deal. There's usually lots of parts available from swap meets etc.
You will need that aftermarket housing though. It will have all the mounting points to be a direct fit into a third gen. Because of the torque arm design, you can't just find a junkyard diff and bolt it in. Most junkyard 9" housings are too wide also so you need to be sure exactly which one will work.
My housing is from a 1970 Ford F100. I use ladder bars so I didn't have to worry about a torque arm mount. I moved all the other parts to mount the springs, shocks etc over to the 9" housing. I also use Ford drum brakes. The only downside to the housing I have is that the pinion isn't in the center. Both my axles are the same length when the majority of all the car 9" diffs have a longer passenger side axle.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Reborn756
Sep 4, 2015 03:42 AM
InfinityShade
Aug 22, 2015 08:00 PM
mustangman65_79
Aug 8, 2015 01:18 AM
