Pinion Nut Question
Old Feb 7, 2005 | 10:41 PM
Geyservillebob's Avatar
Car: '63 Nova Wagon these days
Engine: 3.1L V6
Transmission: 5-speed
Pinion Nut Question
First, I did search first and I think I found the answer to most of the the following questions but I want to be sure.
I had a leak at the pinion that I thought was the seal but turned out to be a leak at the yoke splines (search say this is common, use teflon sealer on splines when reassembling).
I read about the special tool to hold the yoke but thought "heck, what about the e-brake?". I put on the e-brake and attacked the pinon nut only to find that it was basically almost hand tight.
I checked the preload before removing the nut and it was almost non-exsistant ( search says have to remove the ring gear to set preload, manual says no preload is a possible sign of bad bearing).
I think what I read in archives is that this nut should be very difficult to turn. I read 140 ft-lbs in one post. Is this correct?
I suspect Mr. Badwrench reused the old pinion nut and this is a no-no, correct?
Since I don't want to remove the carrier from the rear end to set the pre-load what are my options? I marked the relationship of the pinion to nut and housing but apparantly that references an incorrect pre-load.
Frank
Old Feb 8, 2005 | 04:49 AM
ede's Avatar
ede
it'd be foolish not to set preload or remove the carrier to do so, it isn't hard ot a lot of work. you do need to use a new nut each time you remove the nut. usually the nut will take a bit of effort to break free then be fairly easy to remove.
Old Feb 8, 2005 | 10:01 AM
Engine: 3.1L V6
Is this because the drag of the carrier bearings and ring and pinion mesh effect the total preload measurement?
Couldn't you measure this first and subtract it out?
Does carrier R&R require removing the rear end from the car?
Frank
Old Feb 9, 2005 | 05:17 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yes the pinion nut takes a high amt. of torque when installing.
No, you don't need to remove the diff. from the car to remove the carrier.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Scamo-2.8
May 20, 2016 07:01 PM
lt1z350
Sep 29, 2015 01:50 PM
89fast5oh
Aug 24, 2015 08:14 AM
redmaroz
Aug 16, 2015 11:40 PM
