big or small bearing
Old Feb 14, 2005 | 07:57 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Can someone please give me some clues on how to determine if my ford 9" rearend is a big or small bearing? Im trying to order some baer's and i need this info.
Rearend is from the 70's i think. That would eliminate torino bearing, correct?
Old Feb 14, 2005 | 09:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What size socket do you need to remove the bearing retainer?
If I remember correctly, the small bearing housing uses a 3/4" socket while the large bearing case needs a 7/8" socket. You could also measure the distance between the retainer bolts. Large bearing is 2-1/4" width.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tonys91rs
Oct 10, 2015 03:31 PM
Jorlain
Oct 8, 2015 01:57 AM
64goatman
Sep 9, 2015 01:09 PM
middian
Sep 5, 2015 01:42 AM
