Hold Still...
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
Hold Still...
What's up? I've got a 5-speed tranny in an '89 Camaro RS. When I first bought the car, I could park on a steep hill and leave it in first or reverse and it would hold the car fine. My e-brake does not work, and now the transmission won't hold the car on hills any more. I was just wondering if there is anything I can do about this. I hope someone understands my problem. Thanks.
Car: 4
Engine: 6
Transmission: 5
When you park it that way, the "transmission" doesn't hold the car still; the engine does.
Does the engine turn when you park it like that?
If so, you need some internal work to it bad, because it has no compression whatsoever.
If not, you need a clutch; it's slipping.
Car: 1989 Camaro RS
Yes, the engine does turn, like it's trying to roll-off. What kind of internal problems am I looking at? Also, how can you tell if it is the clutch? I'm sorry for so many questions, but I am still learning everyday. Thanks.
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Car: 1989 Camaro RS
The engine has smoked since day one. It runs pretty good, but it does feel like it has a little more umph to go. I just assumed that since it was the 305 that it was supposed to be like that. It definetly bogs down though. I guess the power isn't really all that great now that I think about it. It still gets me around though. Do you think I should look into getting some new parts?
Engine: L98/383
Axle/Gears: 9"
The only way to fix that would be to spend some big money. if the car seems to run o.k., i would just keep driving it. Make sure you keep that block of wood with you though
Car: 89 Formula
Engine: 355
Try putting it in a higher gear, with it in 1st and Rev you are providing max torq through the gear ratios to turn over the eng, in higher gears there is less torq applied and most likely will not turn the eng over. Of course the fixing the e-brake would also work as mentioned.
Car: '87 IROC, '87 K-10, '95 Ranger
Engine: 350 Tpi, 350 Carb, 4.0 EFI
Transmission: T-5, Turbo 350, Mitsu. 5-speed
RedLeader289
May 28, 2019 01:47 PM
