Pinion lock nut removal
Old Mar 1, 2005 | 03:12 PM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
I'm tryin to replace a bent axle shaft on my 10 bolt, and I can't for the life of me get the pinion lock nut out. Any ideas? Is it locktited in? Do I need a special tool? Thanks!
Old Mar 1, 2005 | 03:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hold the carrier still by sticking a tire tool through it or something; tap on the head of the bolt a few times with a BFH to loosen it up; use a 6-point box end wrench on the bolt, not a 12-point; use a hammer on the wrench, to get some "impact" on the bolt.
DO NOT USE A 12-POINT TOOL!!!!! And tap on the end of the bolt before you start impacting a wrench, to keep from breaking the bolt at the end of the threads.
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I used a high powered impact wrench on my camaro. And another time my buddy and I used about 3 foot bars - one to hold the pinion shaft, and one to turn the nut. That was on a Ford so it might be harder to do on a chevy.
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OK, quick pop quiz.... how many points is your tool supposed to have?
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Old Mar 1, 2005 | 03:46 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Ummm...8 points? I think I'm using the wrong term... I need to take out the small nut inside the differerntial so I can take the axle shafts out, not the big bolt on the outside.... Yeah.
Old Mar 1, 2005 | 05:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The small thing inside the case is the bolt I was talking about; the big thing on the outside is a nut.
Old Mar 1, 2005 | 05:27 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Ok, got it. I'll let you know how it goes.
Old Mar 1, 2005 | 08:47 PM
VILeninDM's Avatar
it is locktite. I had the same problem when I was doing my rear end. I used the 6 point box end wrench just like others said and I still destroyed the bolt head.
If you still can't get it out, use a butane torch to heat up the carrier right where the bolt is while applying constant torque with a wrench. Apparently just a little heat completely deactivates locktite. I got mine out in about 30 seconds with a torch (after destroying the bolt and buying easy out sockets from sears)
Old Mar 2, 2005 | 12:21 AM
Car: 87 Camaro Z28
Engine: LG4, CCC
Ok, I'll keep that in mind. Does that mean I should put locktite on the new bolt? Thanks for the heads up.
Old Mar 2, 2005 | 12:45 AM
VILeninDM's Avatar
assuming you don't destroy the bolt, yes. In my case I bought a new one from the dealer and it already came with locktite on it.
Old Mar 6, 2005 | 12:55 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
So, as per RB's advice, I picked up a 6 point 5/16ths from sears, worked great. Now how do I get the axle shaft out? I've undone the bolt and mostly removed the pinion shaft ( the metal rod about 3 inches long, that's it, right?) and now I'm looking at a whole mess of gears and a spring assembly of some kind. What do I need to remove to free up the axle shaft so I can pull it out? I have a haynes manual, which is no help at all, as it is for my car's year, not the axle. Also, I've found haynes manuals to be generally unhelpful , but yeah. Any ideas?
Old Mar 6, 2005 | 03:42 PM
VILeninDM's Avatar
very simple. Push in the axle you want to remove. Now that the pin is out, it will be able to go in. What you will see is that on the end there is a c-clip. As scarry as it sounds, that is the only thing holding the axle from flying out while you are driving. You should be able to get the c-clip off with some pliers and maybe some kind of picking device (bent niddle end). Once the clip is off, axle slides right out
Old Mar 6, 2005 | 04:35 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Haha, thanks. I already did precisely what ya said... Shortly after posting that question I remembered what to do, I guess I forgot to hit submit when I posted that fact. Anywho, thanks for your help! I've just got to finish getting all that old gasket off so I can put the diff cover back and then I'm gonna take her for a spin. thanks again!
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Apr 25, 2017 07:14 AM
I'llrocya
Feb 2, 2016 11:43 PM
gixxer92
Sep 1, 2015 04:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
