Having a bad week and forgot something, which side of the clutch disk goes towards...
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Which way goes towards the flywheel? The piece that has the spring and protrudes outward a little or the flat side? I have a spec stage 3 disk and it doesn't state which is flywheel side, that or its dirty as hell from the dust. Thanks.
Engine: 4++,350 & 305 CIs
the flat side to the flywheel and the protruding side to the Pressure plate
Car: 4
Engine: 6
Transmission: 5
Look at the disc.
Yes, springs are visible from both sides. But there's more to it than that.
You may notice upon really close, careful and thorough inspection that they are located entirely to one side of the disc, which side also happens to have the hub on top of it. Therefore they are not "on both sides". They are completely off to one side.
That's the side that goes away from the flywheel, toward the clutch.
I assumed thats the side you were talking about, I just wanted to be 100% sure. Im under a lot of stress this week and don't have time to be making mistakes, once again, thanks.
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Crucial point here: he has an LT1 T56. The side that protrudes goes toward the flywheel on a pull-style clutch.
FWIW I loved my SPEC stage 3. It lasted about 5 years and 60k or so miles, and grabbed like a teenager on a hot date. I went to a stage 2 when it wore out, since I'm keeping it N/A and she rarely sees the track.
novaderrik
Aug 10, 2015 12:44 PM
rsrmoore
Aug 7, 2015 08:44 PM
