tranny cooler big enough?
Old Mar 12, 2005 | 10:08 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i just recently installed a 2400stall 10" ati converter with my freshly rebuilt/beefed up 700r4. this converter does have lockup and performs very well. i want to keep it that way. currently, i have the coolant lines hooked up to the rad, just like stock. i've heard this is OK, but to get an aftermarket, stand alone cooler on as soon as i can. well, i had a cooler laying around the shop, my dad said it would be ok to use. once i got it outta the box, it was really small. wondered if it would be ok to use. it's like 9"x5 1/2"x1/2" will it do the job or am i better off with the stock cooler for now till i can buy a larger cooler?
edit: the water temp for the motor never gets hotter than 175*, does this help? also i have an electric coolan fan that i run from the time it gets to 160* till i shut the car off.
Old Mar 12, 2005 | 01:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've compared temperatures with and without an extra cooler and it doesn't seem like it takes much to make a big difference in fluid temperature. It will probably work, especially when you consider that you'd probably get away with just using the stock cooler.
Old Mar 12, 2005 | 01:14 PM
mw66nova's Avatar
Engine: 7.0L
could i possibly run it in-line with the factory cooler to have two coolers?
Old Mar 12, 2005 | 01:47 PM
mw66nova's Avatar
Engine: 7.0L
thinking i am going to run both the factory and the aftermarket cooler. which line should i splice into, the top or the bottom. the bottom one is the one i am thinking, cause it should be the return line, but i'm not sure.
Old Mar 12, 2005 | 02:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I run both. The bottom line is the supply line to the cooler, not the return line.
Old Mar 12, 2005 | 02:21 PM
mw66nova's Avatar
Engine: 7.0L
good to know, i will cut the top line then?
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
3.8TransAM
Oct 1, 2015 07:47 PM
