700R4 problems major HELP ASAP
Old Mar 14, 2005 | 10:52 PM
92rsstallion's Avatar
Car: 92 rally sport
Engine: 305ci
Transmission: 700R
Big problem, every since i can remember my car would slip when shifting between every gear. Most noteably between 1-2 and 2-3 supposedly its the clutches inside worn out so i've been told. Could it possibly be the governor?? doubt it but, i don't have very much knowledge when it comes to trannys. Also today i think the tranny is finally quiting. I was pulling out of a local drive normally, noticed it shifted "normal/slipped into 1-2 but the shift into 2-3 didn't happen and it definetly would not shift into OD. I'm definetly stumped my guess would be the clutches worn out but any feed back ASAP would be greatly appreicated this is my daily driver and i don't want to get ripped off by some transmission place.
Old Mar 14, 2005 | 10:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Sounds like the trans is worn out. You could try readjusting the TV cable for max tension at WOT just for yucks. But, from the sound of it the trans needs to be freshened up.
BlueIroc-Z
Jun 9, 2019 03:22 AM
someone972
Aug 30, 2015 12:52 AM
g.l.mos
Aug 22, 2015 12:02 AM
zeitghaist
Aug 18, 2015 07:33 AM
hokis
Aug 9, 2015 03:57 PM
