upgrading to posi
Old Mar 15, 2005 | 06:06 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
upgrading to posi
Well i have a 10 bolt on my firebird and i'm not sure on my camaro (it's at the shop getting paint ) my camaro is a limited slip, does anyone know any good places to buy an upgrader/new gear kit to make it posi?
and also, when i had the break pressed all the way down, the right back tire was spinning, it wasn't gripping for squat, what's up with that?
and finally, i know this is a newbie question but, how do you tell what size gears are in there without taking it apart. i'm pretty sure i have a 3.23 in there now but don't feel like taking it apart to check any help?
Old Mar 15, 2005 | 06:56 PM
TN87TA's Avatar
Car: 87 TA
Check the RPO code sticker in your console. The G codes are for the rear end.
GU2 - 2.73
GU4 - 3.08
GU5 - 3.23
GU6 - 3.42
GW6 - 3.27
GM3 - 3.45
GT4 - 3.73
G80 - posi
G92 - performance
The RPO code is also supposed to be stamped on the top of the right axle tube.
Old Mar 15, 2005 | 09:27 PM
rsn932's Avatar
Re: upgrading to posi
limited slip is the same thing as a posi
when you do a brakestand, the tires spin, they dont grip, thats the whole point of doing them (not saying thats a good thing)
Old Mar 15, 2005 | 11:23 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
If it's the factory rear end and you are sure the gears have never been changed and you can't find the RPO code on the rear. Call your local Chevrolet House, Parts Department/ give then the last 8 digits of your VIN and they can tell you everything you need to know about your rear end.
Old Mar 15, 2005 | 11:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How do you figure that? There's no relevant information encoded in the VIN, and his car is over 20 years old.
Old Mar 16, 2005 | 12:10 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
last 8 didgits is car number, from thier they could prolly pull up the info on that particular car #
Old Mar 16, 2005 | 01:08 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Because I've done that with all the camaro's I've ever owned. And I didn't know his car was over 20 yrs. old/ it was not posted.
I'm not sure how far they can look back (years), but that's the best way I've found if there is no RPO codes on the rear.
Old Mar 16, 2005 | 06:05 PM
Car: '94 Z28
Engine: LT1 350
Thanks guys, i now know i have a 3.42 in my bird and i don't know about my camaro, that's still gonna be in the shop for a while....
dbrochard
Jan 28, 2016 08:42 AM
Prodigious
Sep 18, 2015 05:23 AM
georgiaslim45
Sep 9, 2015 08:11 PM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
