400HP Transmission?
Old Mar 20, 2005 | 09:39 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
400HP Transmission?
Ok I am dropping in an unknow motor yet (havn't decided) in my 91 RS. My car currently has the stock automatic tranny and I presume with the new motor I will need a new tranny
(currently a stock TH-700R4). Now even with the power going to be around 400hp+ I still want to keep the tranny an automatic one. Now heres where I am trying to figure out where to go from. Should I drop in something like a TCI TH-700R4 or something like a TH-400 or a TH-350. I would like to be able to throw shift the car but I still want the car to be just as reliable if she turns into a daily driver again. Now is there any perks to a certain one for something with 400hp and used a lot more at normal speeds then track conditions? Is there a reason why I would want an overdrive transmission?
I aploligize if there stupid questions, I recently ditched two fords and have joined the GM community. (No I didn't buy the fords they where hand-me-downs)
Thanks,
Mike
Old Mar 20, 2005 | 09:46 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I have had terrible luck with tci products. I do not recommend them. I am a fan of the 700r4 overdrive transmission. Great first gear ratio and overdrive also. 350 and 400 trannies are stronger in stock form. No overdrive though. If I were building a drag car I would go with a 400. A street strip car and I would use the 700r4.
Old Mar 20, 2005 | 09:55 PM
crrllmich's Avatar
Engine: L03, LS1
So who do you recomend I get the 700 from? Or you saying just use the stock 700?
Old Mar 20, 2005 | 10:15 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Some people swear by the 700's, others swear at them. I have been running a stock 700 with great results. On spray it has gone hi 10's but often runs bottom 12's on motor. It usually cuts a 1.625 60' time but has cut a 1.505 for a best. My trans has been assembled by a friend 10 years ago. No fancy parts in it. Just a blueprinted box and a shift kit. I wish I had installed a heavy duty reaction shell ($50). Where you buy a trans is your call. I now do my own. Probuilt is a sponsor on this forum and he has a good reputation. My budget is always tight so I cannot afford a serious trans. They run from $1500- $3500 through out the country for a "top notch, heavy duty" model.
Old Mar 20, 2005 | 10:17 PM
crrllmich's Avatar
Engine: L03, LS1
Ok so if I use the stock trans I should have it rebuilt and reinforced on some common parts? Sorry for all the questions.
Old Mar 20, 2005 | 10:26 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
There is a ton of aftermarket stuff for a 700. Pump upgrades, hardened input shaft, 5 pinion planetaries, "beast" reaction shell. Heavy duty clutch plates and bands are available as well. If I were building a 400-450 hp 700, I would use a "beast, raybestos paper clutches and band and a shift kit. I would also blueprint the clearances in the clutch packs. Most good shops do. I would install a b&m shift kit, Not because they are great, but they work well for me and I like the hard shift. I have never seen the planetaries or input shaft break on a lower hp motor. I have also been using a stock 10 vane pump with no issues yet. I build transmissions for hobby. My advise/opinion is just that....opinion. I install floorcovering for a living. It works well for me though.
Old Mar 20, 2005 | 11:31 PM
kd5boc's Avatar
Car: 92 RS
www.bowtieoverdrives.com
They carry 700-r4's and the 200-4r's as well.
GREAT customer service, and they can send you quotes for about any option available.
They test them in a car before they ship to you.
Good Luck!
Tom
Old Mar 22, 2005 | 11:58 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Give Dana @ ProBuilt a call. I absolutely love my Street/Strip 700r4.
http://www.700r4l60e.com/
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
abray1
Sep 10, 2015 04:53 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
