6 speed driveshafts fit autos?
Old Mar 21, 2005 | 05:26 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I have an automatic transmission in my 86 TA and I want to put an aluminum driveshaft in it. Some one here has a shaft from a 6 speed and said it only works with other 6 speeds. Is that true?
Old Mar 21, 2005 | 05:59 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The answer my friend
is blowin' in the wind
or in a search.
Old Mar 21, 2005 | 06:14 PM
Car: 86 T/A
Engine: HSR 355
I did search and all I found was that they are universal. However the guy selling it says it only fits 6 speeds.
Old Mar 21, 2005 | 06:37 PM
jmd's Avatar
jmd
Logical conclusion: he's wrong.
Old Mar 21, 2005 | 06:51 PM
Car: 86 T/A
Engine: HSR 355
I'm not about to buy something unless I know for sure. So many times people on forums forget things or are just wrong so I am looking for a definite answer.
Old Mar 21, 2005 | 06:56 PM
jmd's Avatar
jmd
Thirdgen.org > most "guys selling parts."
Old Mar 21, 2005 | 07:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Amen to that.
Honestly though the advice here on TGO is like no other. To varify your answer try a few searches. You shoud find re-afirming posts that back up what jmd is saying. It is hard to go wrong with the extensive archives that TGO has.
Old Mar 21, 2005 | 08:13 PM
Car: 86 T/A
Engine: HSR 355
I still haven't found 6 speed specific related answers. Its always "82-02 5 speed trannies are all interchangable".
Old Mar 21, 2005 | 08:40 PM
jmd's Avatar
jmd
Sometimes knowledge takes time.
<--- + a few T56 swaps under my belt + T5 swaps = I can tell you that all 83-02 f-body driveshafts from T5, T56, 700-R4, and 4L60 cars interchange.
Old Mar 21, 2005 | 08:53 PM
Car: 86 T/A
Engine: HSR 355
Thanks alot!
Old Apr 5, 2005 | 01:04 PM
90_formula_305's Avatar
Which ones are aluminum? can you tell by vin.? Been searching, I'll go to vin break down again.
Which models came with aluminum driveshaft?
Old Apr 5, 2005 | 01:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The ones that a magnet won't stick to.
You just gotta go look.
AFAIK however, all LS1 cars have aluminum; those are the easiest ones to get, besides.
Old Apr 5, 2005 | 01:26 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Some LS1 cars did recieve a steel shaft. They were the A4 cars that were crippled with 2.73 gears. Those gears kept the rotation speed down of the shaft and necesitate (is that a word?) a lightweight balanced aluminum one. Many LT1 cars had steel shafts as well. My '95 M6 Z had a steel shaft.
Old Apr 12, 2005 | 12:52 PM
MerF's Avatar
Car: '88 IROC convertible
Engine: Freakish 305 TPI
Transmission: Dying 700r4
Axle/Gears: LT1 rear
Found this thread while searching, I swear.
I called a local junkyard that happened to give up an LS1 driveshaft to another local 3rd gen'r for $100 out the door. But when I asked if they had anymore, they told me there were two options, with or without a "slip yoke". Any thoughts? Or are they indexing their parts seperate for no reason?
Otherwise I'm happy to see that all shafts are universal!
Old Apr 12, 2005 | 01:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You want one with the "slip yoke" still on it. No point in getting one that's missing pieces.
Old Apr 12, 2005 | 01:15 PM
MerF's Avatar
Originally posted by RB83L69
You want one with the "slip yoke". No point in getting one that's missing pieces.
So the slip yoke is basically a part of the driveshaft? Cool. Thanks!
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
theshackle
Aug 23, 2015 03:49 PM
jbd1969
Aug 17, 2015 07:06 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
