first post rookie needs help axle code
Old Mar 25, 2005 | 10:30 PM
robby_0351's Avatar
Car: 83 Trans Am
Hello-This is my first post. Let me know how I can get the information on my 83 trans am axle code
5PH C173 2 is stamped on my axle tube. I have rear disc brakes. Any help would be great.
Also the plate on the radiator support has these numbers on it
D06D 2FS87 L 230433
22C 27 L 27 J W
AR9
D NS 27457
Anyone know what this is all about?
Old Mar 26, 2005 | 12:34 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
what are you trying to figure out . I kinda misunderstood your post a bit.
Old Mar 26, 2005 | 06:26 AM
ede's Avatar
ede
you can find info in your manual, think there is a decoder here. if you really want to know what you have and not what it had pull the cover and look.
Old Mar 26, 2005 | 03:01 PM
robby_0351's Avatar
Car: 83 Trans Am
For Clarification-I would like some help on figuring out my axle code which I listed.
I also listed what is printed on the tag that is on the radiator support and request any help with that information.
ede- I don't know the manual your are speaking of. My Haynes manual has some codes but does not have mine listed.
Old Mar 26, 2005 | 11:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
http://www.hioutput.com/tech/ratio.html
5PH? sure it's not 5PN? I think that shows it to be 3.73 posi if it's an N....
Old Mar 26, 2005 | 11:19 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
what kind of motor....
lg4 4bbl 305
l69 4bb high output 305
lu5 cfi
Old Mar 27, 2005 | 03:09 PM
robby_0351's Avatar
Car: 83 Trans Am
It has the 305 4 barrel. I don't know much else about it. I didn't get any paperwork and it has no decals on it.
The stamping on the axle tube is not really clear except for the 5
Thanks for your help.
Old Mar 27, 2005 | 08:14 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
the 'PH' indicates 3.23 gears non-posi i believe
Old Mar 27, 2005 | 08:39 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Which would stand to reason based on the year and engine..
Old Mar 27, 2005 | 09:38 PM
robby_0351's Avatar
Car: 83 Trans Am
Thanks folks-I thought it might be a 3.23 and was sure it wasn't a posi from the rotation when I jacked it up. I have disc brakes. Unless I can find a better rear end cheap I will probably live with the 3.23. I would like to put in a no slip though. Anyone ever do that? I need to open it up for seals anyway.
specialized
Jun 18, 2022 09:26 AM
Chuck84TA
Jul 15, 2016 09:05 PM
red90IROCls1
Aug 25, 2015 06:56 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
