Taking down trans - difficult?
Old Mar 27, 2005 | 02:47 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Hey guys,
I need to get a transmission leak taken care of and would like to get it rebuilt. However, the price difference is pretty big if I can just deliver the trans to the shop compared to if I just bring the car there and have them do all the work.
So, is it doable to take the trans (auto) down with the car only sitting on jackstands - and how much work am I looking at?
Thanks!
Ken
Old Mar 27, 2005 | 03:16 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
i've never actually taken the trans out of a camaro exactly, but i have taken several out of other cars. its definitely doable on jackstands, and it should only take a couple hours probably.
Old Mar 27, 2005 | 05:43 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yep, it is definitely doable. Just make sure the car is up in the air enough so that the transmission can slide out once it's disconnected from the engine . You are going to need a nice assortment of 3/8" extensions for the upper engine-to-tranny bolts, too.
It's been awhile since I've removed/installed a tranny, but it should go something like this for a 3rd gen: raise and support car, disconnent the 2 or 3 electrical connections (lockup, VSS, ?), disconnect shift linkage, disconnect TV cable, remove dipstick and dipstick tube, remove driveshaft, disconnect speedo cable (if equipped), disconnect torque arm, remove inspection cover, unbolt the 3 torque converter-to-flexplate bolts, support tranny with jack and block of wood, remove tranny mount, remove tranny crossmember, unbolt the 6 tranny-to-engine bolts, and then slowly lower the tranny down and out of the car.
I may have forgotten a couple of steps. But, like said earlier, it should only take a couple of hours.
Old Mar 28, 2005 | 02:35 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Sweet! Thanks a lot guys!
Ken
Old Mar 28, 2005 | 04:34 AM
CrazyHawaiian's Avatar
Car: too many ...
Yeah its do-able in a driveway on jackstands. Need really tall jackstands if you're gonna use a transjack. I've done it a few, not too bad.
Old Mar 28, 2005 | 09:29 AM
Faded's Avatar
Car: '91 Firebird
Get an extension about 12 inches long with a wobblie at the end for getting those upper bolts.
Old Apr 6, 2005 | 11:00 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
dont forget the trans cooler lines. I cant remember, but do you also have to take off the starter? its been a while since I pulled mine, but looks like I will be doing it again real soon.
Old Apr 6, 2005 | 11:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
THe upper bolts are MUCH easier, with a little shortie 9/16" box wrench from above.
Old Apr 6, 2005 | 11:30 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Just like everbody said. Make sure its way up in the air. I mean WAY up in the air.
Old Apr 6, 2005 | 02:52 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
For the 700-R4 you dont need to remove the starter. Ive done it about 4 times now with jackstands. Borrow a friend when your ready to lower the trans out.
Old Apr 6, 2005 | 03:01 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
i tired that when i pulled my 700. i could not get to them. i tryied every thing possible to get to them from the to. i finally got pissed and got all of me extentions and got them from the bottom. i found out that my windshied has a lot of flex in it. when i got mad i threw the wrench as hard as i could and it hit the windsheid and it flexed in but didn't break.
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Mar 5, 2017 06:37 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
jharrison5
Aug 19, 2015 05:53 PM
