T-5?
Old Mar 31, 2005 | 12:49 PM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
T-5?
Anyone know if a T-5 from a mustang is the same basic trans (ie, dimensions, mounting, tailshaft, etc.) with a different bell housing? The T-5's from the camaros have a really steep 1'st gear (three something) that is basically useless in my application. Also, I like the benefits of the .63 overdrive with my 4:56 gears. Has anyone tried this type of swap?
Old Mar 31, 2005 | 01:05 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Same basic things, shifter is in a different location and could be wrong but the input shaft spline count and length are different.
In other words, it will not work, been asked quite a few times.
Old Mar 31, 2005 | 01:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No it will not bolt up. Not even close.
The Mustang gear ratios are considerably wider than GM ones, with a much steeper first gear than GM ones; GM V8 ones, anyway. They're jsut about like the 6-cyl ones in these cars.
The TBI 305 cars come with a .63 5th gear.
Old Mar 31, 2005 | 01:14 PM
Car: 85 Berlinetta
Thanks for the reply. They're a dime a dozen, so I was just trying. Guess that settles that question!
Old Apr 2, 2005 | 12:58 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
from what ive been reading. you can put a mustang t5 in a c3corvette(my father and i own one.) for a mustang t5 to go into a gm car you need an adapter plate(found at Gforce) mustangs are 10spline clutch and then just use a gm pressure plate. im thinkin you could use a mustang t5 in a firebird or camaro with a little different adapter plate. the mustang is 1/2" longer input shaft and a chevy to ford bushing which can be bought. im not sure about our crossmember.... but the mustang t5 and gmt5 are somewhat similar in external dimensions...so i think a little modifying would be required.
http://forums.corvetteforum.com/show...highlight=3550
thats the forum i was reading. its very intersting
Old Apr 2, 2005 | 04:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Putting one into a C3 doesn't have much to do with the issue at hand. A manual transmission doesn't fit into one of these cars like it does into a C3, which doesn't rotate the trans 18°, and doesn't have a torque arm, among other things.
Go do it, and after you've done it, come back tell us it works.
Until then, it hasn't worked for anybody else.
So until you get it to work, it doesn't; and it's not very helpful to tell people stuff like that, if you're just guessing and don't know what you're talking about.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
