TH350 tranny lines...use from 700r4?
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I am gathering parts to swap a TH350 into my Z this summer.My car stock is a 4 speed car with a T10 so I need everything.I have most everything I need to do the swap except for tranny cooler lines.Can lines from a 700r4 car be used?They are a dime a dozen at the JY so I can pick up a set cheap.Or are all of you that swapped from a 700 to a 350 making all new lines?Do the tranny side of the 700 lines screw right into the 350's fittings if they can be used?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
When I switched from my 700 to the 350, i used the stock lines. They just needed to be "tweaked" a little to work.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I finally got rid of my steel lines and use steel brainded 3/8" hose.
My original 700R4 lines were also hooked up to a TH350, TH400 and finally a powerglide. The fittings are all the same. They just need to be bent slightly to line up.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
