TH700R4 questions....
Old Apr 4, 2005 | 06:55 PM
blownsbcpwr's Avatar
just the other day i was on the freeway a few miles from my house and my tranny started slipping when i'd give it gas. it felt like nothing was applying at all. anyway, low gear is the only gear i can get around in but if i put it in drive or OD....once it shifts out of first the rpms just go up as if it was in neutral. reverse also works too. i have pulled apart a few transmission in school, but i'm no trans genius by any means. if anyone has had a similar problem could you help me out? i was thinking that maybe the kickdown band isn't applying or something.....but maybe i have no idea what the hell i'm talking about. also, if i'm going to rebuild it, i want to do a performance rebuild....so if anyone has any words of wisdom about that, i'd really appreciate it. thanks alot guys.
Old Apr 4, 2005 | 06:57 PM
sorry, forgot to mention it's an 89 formula with a 305. all stock for right now but soon to change.
Old Apr 6, 2005 | 01:41 AM
Pro Built Automatics's Avatar
If you lost all the forward gears all at once except for 1st, then you most likely stripped the teeth off the governor. Remove governor, and have a new gear installed.
Old Apr 10, 2005 | 11:42 PM
thank you
Cleotiz
Jan 6, 2018 08:56 PM
camaronils
Sep 20, 2015 02:57 PM
LilJayV10
Dec 18, 2001 06:20 AM
Ward
Nov 26, 2001 08:02 AM
Ward
Nov 26, 2001 07:49 AM
