another rear end
Old Apr 6, 2005 | 11:48 PM
Tweaked's Avatar
Car: 88 t/a red w/body kit
Engine: 305tpi...355 carbed
another rear end
i have a 10 bolt out of a 94 formula. there is big hole that looks over the top of teh gear, it is open, there is no cap or bolt on it, wut is supposed to be there?
Also what weight gear oil should i put in the diff.
Old Apr 7, 2005 | 05:05 AM
ede's Avatar
ede
3/8 NPT plug, if it's the fill hole you're talking about. i use 75w-90 M1 gear oil
Old Apr 7, 2005 | 05:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's on the VERY TOP in the center, it's where the ABS wheel speed sensor goes.
I have no idea, other than a sensor, what would fill up that hole.
Old Apr 7, 2005 | 10:56 PM
Tweaked's Avatar
how should i go about pluging it?it is right above the gear on the top of the dif. (of the rear end was on the car and you had the car jacked up the hole would b faceing the gas tank)
Old Apr 8, 2005 | 06:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get an old sensor out of a car at the junkyard; or figure out what threads it is and use a pipe plug, or if it's not threaded use a freeze plug, etc.
It's just a hole.... no pressure or heat or anything.... not rocket science.
Old Apr 9, 2005 | 02:12 AM
Tweaked's Avatar
wanna b sure, if somthing breaks off in there i'm gonna go f*%kin crazy
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
