Will I make it?
Old Apr 13, 2005 | 06:53 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Transmission: TH350 3200 stall
Axle/Gears: 4.10's
Will I make it?
Im just finishing up my manual to auto tranny swap. It's a TH350 with a 2800 stall speed with 4.10's out back. My RPM range is somewhere around 2000-7000rpms. Will I make it all the way down the track? Seems like I might be running out of gear or rpms.
Old Apr 13, 2005 | 07:25 PM
HawaiianRS's Avatar
Car: 1989 RS
Engine: 5.0
Just run some 33" mudders on the back and you'll be fine
Old Apr 13, 2005 | 08:08 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Axle/Gears: 4.10's
How say? From expierence? Am I really that bad off or are you just sounding off just to say something?
Has anyone actually ran this or close to this combo?
Old Apr 13, 2005 | 09:14 PM
brutalform's Avatar
Re: Will I make it?
Your 350 trans has a first gear ratio of 2.52, and it will tolerate steeper gear sets. If it was a 700R4, with its 3.06 ratio, even 3.73s would be a bit steep. too much rear gear, and too much 1st trans gear, will give you an almost useless launch ratio. Thats why you always hear of the LS1 guys going with steep gears, because the 4L80E has a 2.43 ratio. BTW, what else is in your engine, as far as camshaft, and C/R ratio goes? IMO, a great move going from a stick to an auto.
Old Apr 13, 2005 | 09:38 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Axle/Gears: 4.10's
355 4 bolt main block '87
.510 lift cam
11:1 comp flat top pistions
Dart heads 200cc 64cc chambers 2.02intake 1.60exhuast
holley 750 dp with bigger jets
1.6 roller rockers
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
