trans question
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
trans question
ok. i want to get a manual trans for my swap. its an older pre 86 block(79 to be specific) 350. One person told me i cant use an lt1 t56....is this correct. I didnt think so but i wasnt sure. Also the engines gonna be making over 300hp, and plus torque. So a t5 is really just dumb. So my question is, what tranny should i use. a t56....or a tremec....any others...i dont want to spend a crap load of money. but i know that good transmissions cost money. so any info would help alot. also what flexplate do i need the one i have is chipped and missing teeth. also any suggestions for a clutch and pressure plate...?
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
the best and cost-effective option, would be a T-56 from a '94-'97 LT1 Camaro/Firebird (the corvett one WILL NOT work), you will need a adapter flywheel, centerforce makes one and summit sells it, as it uses a pull-style clutch(it pulls the throughout bearing, insted of pushing it), and you will need to fabracate, or buy an adapter crossmember, also the speedo uses a 40,000 pulse per mile insted of the 4,000 pulse per mile of our third gens, digital dakota makes a adapter box for this, other than those items it's a bolt in, there is also a tech artical on this site that goes over all the installition proceders, it will cover anything I missed
thanx much.
would it be cheaper to get a gforce t5?
would it be cheaper to get a gforce t5? Senior Member
Engine: 383
never really looked into it...I think it's just a beefed up T5, I'd still go with the t-56...
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
