HELP! Shifter won't come off???
Old Apr 26, 2005 | 05:24 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, I have the B&M shifter, and I'm trying to take it out. I removed the 4 bolts surrounding it, but it feels like it is still bolted on! What am I missing?
Old Apr 26, 2005 | 06:16 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
make sure its in nuetral & tap base with deadblow
Old Apr 27, 2005 | 12:46 AM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
It's probely sealed with rtv which might give it that impression of being bolted if it hasn't been removed in a while. Somtimes that stuff really sticks. I just stick a screwdriver under the lip at the base of the shifter and pry it off.
Old Apr 27, 2005 | 08:48 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I did that... and bent it!
Old Apr 27, 2005 | 09:19 AM
kal's Avatar
kal
Car: 1983 Firebird
WOW!! That wasn't supposed to happen. How bad is it? Did it come off at least?
Old Apr 27, 2005 | 09:34 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Nope, tight like it's still bolted down
Old Apr 27, 2005 | 02:31 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
There's nothing holding it on except those 4 bolts and RTV. So if you have removed those 4 bolts.........all that's holding it on is RTV (deductive reasoning), which actually does a pretty good job of sticking parts together when applied properly, and has been known to bend stuff while trying to seperate parts.
Old Apr 27, 2005 | 02:37 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok then, I'll pry away lol
Old Apr 27, 2005 | 02:48 PM
Engine: 5.7, 5.0
Assuming you did not install the shifter, becasue then you wouldn't have asked how to uninstall it (deductive reasoning again). Something you should keep in mind: You never know what some other a-hole did, for all you know the guy who installed the shifter used JB Weld instead of RTV. look around see if you see any RTV around the edges. If you see RTV, then pry away. If you see some other adhesive, well lets just hope you don't.
Old Apr 27, 2005 | 02:50 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Maybe it is a very clean application of RTV? I don't see any other than the stuff that was on there before...
Old Apr 27, 2005 | 11:34 PM
Meanie5470's Avatar
Car: 1985 Iroc-Z28
Engine: 350 (carbed)
try tapping the base off with a dead blow. If that doesnt work try slamming the shyt off with the dead blow (on the base of course). Trust me theres no way to damage a ripper shifter with a dead blow.
Old Apr 28, 2005 | 08:13 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, sounds like the only option! It also sounds like this has happened to you!
Old Apr 28, 2005 | 11:29 AM
Meanie5470's Avatar
Car: 1985 Iroc-Z28
I dont think Ive ever seen a clean application of RTV in my life lol
Luigytico09
Oct 1, 2015 08:46 AM
ndndndnd
Sep 28, 2015 08:00 AM
