Anyone have a link or site on rebuilding a posi?
Old Apr 26, 2005 | 08:42 PM
nuck's Avatar
Looking for some detailed step by step instructions on rebuilding a 3rd gen factory posi. Anyone?
Old Apr 26, 2005 | 09:19 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what type. not all are rebuildable
Old Apr 28, 2005 | 12:01 AM
nuck's Avatar
Sorry. Unit is a 10 bolt 7.5" and 26 spline.
Old Apr 28, 2005 | 05:19 AM
ede's Avatar
ede
what do you mean by rebuild? what you wanting to replace?
Old Apr 28, 2005 | 05:55 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
http://www.streetrodstuff.com/Articl...rain/Rear_End/
http://www.ws6transam.org/10bolt.html
Old Apr 29, 2005 | 12:23 AM
nuck's Avatar
The clutch pack I guess. The posi is from a swap meet so I figured it would be a good time to maintenance it since it is sitting on a bench right now. However the FULLSIZEchevy site says when the G80 Eaton posi's start to go they are done so maybe I should just throw it in. Assuming the G80 in the pickup and Camaro both live and die the same way. What do you think?
Old May 20, 2005 | 12:00 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
http://www.fullsizechevy.com/fscu/eatontech/
The site indicates that only the Eaton Locker would be difficult to rebuild as when it blows, it destroys other parts of the axle. As long as you were doing a full rear axle rebuild involving replacing all bearings, seals, clutch packs, gears, etc...it should be OK as long as any damaged parts were replaced. That may become financially unrewarding if new units are available for less than the rebuild cost -- but I'm not sure if they are.
Of course, if the unti did not blow while in YOUR rear end, then you could be fine as the metal particles which destroy everything would have killed the rear the unit was pulled from. I'd recommend pulling the clutch pack to see if it has metal shavings all over as these will screw with any rear you place the eaton into.
Old May 20, 2005 | 12:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There were a couple of "factory" posi units used back then. The "factory" didn't make either of them.
One was the Eaton Gov-Lock. There's no sense in "rebuilding" one of those.
The other was an Auburn. You can download a whole manual from their site www.auburngear.com but there's no parts available for it.
Old May 20, 2005 | 08:50 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
is there a posi worth rebuiding? serisously.... since i know my auburn is only gonna last so long, and when it goes, it's done, what can i buy that's rebuidable, and worth rebuiding in the process? when i say rebuidable, i mean replace the clutch pack(s), springs, and gears? i was thinking about a detroit unit of some kind, or an Eaton, but not a factory piece. I'd always heard the eatons were good posi's worth keeping around.
Old May 20, 2005 | 10:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The better Eatons are, like the 19599; but not the Gov-Lock.
Jorlain
Oct 8, 2015 01:57 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
SlowAZ28
Sep 2, 2015 05:19 AM
