4th gen rear end in 3rd gen car???
Old Apr 26, 2005 | 08:48 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
what are the differences between a 95 Z28 rear end and a 3rd gen one, will it bolt in? and if not, what is different???
ps-my 3rd gen already has rear disc..
Old Apr 26, 2005 | 08:55 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Bolts in perfectly if I remember correctly. Except it is about 4" wider overall.
So each wheel will stick out almost an extra 2" over the 3rd gen rearend
Old Apr 26, 2005 | 09:16 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
you need to alter the brake lines i think for different fittings???
Since the rear is wider you have to use 4th gen wheels, everything else is a complete bolt in.
Old Apr 26, 2005 | 11:01 PM
sleeeper91's Avatar
Car: 91 rs with ls1
Engine: ls1
Transmission: t56
take the stock lins off the 3gen rear and bolt them up to 4 gen i have a 99 rear in my 91 camaro. and the brake lines mated right up.
Old May 1, 2005 | 02:59 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
how much stronger are the 4th gens?
Old May 1, 2005 | 08:28 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The aren't any stronger than any other 10 bolt. An X amount of power doesn't kill them, rather abuse will do the deed instead. You will need to modify your E-brake as well as possibly stretch your fuel lines. Your stock wheels will stick out about 2" farther on each side. You would want to conisder running 4th gen or vette wheels. This will require you however to use spacers up front. A few searches will bring up 4897538495835 threads devoted to this swap.
Old May 2, 2005 | 05:46 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
why do people do the swap? for the disc brakes?
Old May 2, 2005 | 05:59 AM
ckjoshz28's Avatar
disc brakes, posi and better gears allready installed.
Old May 2, 2005 | 02:15 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
So that they can run 4th gen wheels with only a pair of spacers for the front and get better brakes and gear ratios for cheap.
Old May 2, 2005 | 05:12 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
I think you meant you will have to stretch the brake lines.
The fuel lines arent touched.
Old May 2, 2005 | 06:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I did mean brake lines. I have no idea why I said fuel. I must have already mentally moved onto my next post Thanks for keeping me straight
Old May 2, 2005 | 07:11 PM
cali92RS's Avatar
Car: White KSwisses
They dont pay moderators enough anymore
Old May 3, 2005 | 04:28 PM
TheKeeling's Avatar
Car: 1985 Z28
Engine: 5.7 TPI Crate Motor with Vette PROM
Axle/Gears: Richmond 3.42
Anyone have pics of a car/their car with the 4th gen rear?
Old May 3, 2005 | 04:53 PM
Zepher's Avatar
Old May 3, 2005 | 11:29 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
so one 4th gen rear is as good as another? say a 93 rear would be the same strength as an 02 rear, assuming they had the same amount of wear and tear on them? (disregarding the one is now 12 years old)
Old May 4, 2005 | 04:08 AM
Zepher's Avatar
yes
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
