Wiring Help, Mystery Wire Near Tranny!
Car: 88 camaro
Engine: 305 t.b.i
i recently have been doing a motor swap in my 88 camaro. i had a v6 and i put a 305 tbi in. i am making all my final connections and i am almost ready to fire her up. i can not find where one of my wires go from my harness. there is an connector for the lockup system on the drivers side of my 700r4 transmission. that is connected but i have another wire from there that is no longer than 8 inches, it has to connect to something very close but i can't find it. please, any input that u think might help i would gratly appreciate.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Wiring Help, Mystery Wire Near Tranny!
Originally posted by kdubdizzle.but i have another wire from there that is no longer than 8 inches, it has to connect to something very close but i can't find it. please, any input that u think might help i would gratly appreciate.
Car: 88 camaro
Engine: 305 t.b.i
mystery wire
there are two wires,purple and yellow. at the end of these wires is a small connection device. it is oval shaped. there are two circles inside with small needle like prongs. that is the best description i can give. i tried to send a pic but it says my file is too big. sorry!
Car: 88 camaro
Engine: 305 t.b.i
i have a pic
http://profiles.yahoo.com/kdubdizzle i could not get a pic to work so i put the picture of my wire on my profile at yahoo.
Re: i have a pic
Originally posted by kdubdizzle.http://profiles.yahoo.com/kdubdizzle i could not get a pic to work so i put the picture of my wire on my profile at yahoo.
Re: Re: i have a pic
Originally posted by Street Lethal
Oil Pressure switch. It's located just above you're oil filter on the side of the block...
The Oil Pressure switch should have an Orange & Tan/White wire... not a purple & yellow. Let me double check something on my own 88.
Originally posted by Benm109.Sounds like the connector for the VSS on the tailshaft of the tranny.
Edit: Just checked the Vehicle Speed Sensor on my 88, and although the wires are different in color... the connector seems to match perfectly.
Car: 88 camaro
Engine: 305 t.b.i
wire
could not find anything on the tail shaft of my tranny, i have looked all around and it does not look like it would connect to my transmission. look on my yahoo profile and see, i have the pic there. thank you
Re: wire
where is the vehicle speed sensor exactly?
You're existing 2.8 automatic tranny did not come with a VSS. If this is the case, you'll need to buy a buffer...
Edit: Although I don't see how that is possible (in reference to a missing 2.8 VSS), but then again, this is according to Chilton...
Car: 88 camaro
Engine: 305 t.b.i
i do not have the v6 tranny in, i swapped the engine and tranny together. i don't know why i don't see the connection, it should be simple, the wire can only go so far
Originally posted by kdubdizzle....it should be simple, the wire can only go so far
Edit: My apologies, I thought you were replacing it.
Car: 88 camaro
Engine: 305 t.b.i
wire
is this bolt on the drivers side of the tranny or what? the funny thing is this motor and transmission worked great before i swapped it to this car. i never had a problem with how it ran, i dont remember if that was connected to something or not when i took it off.
Car: 88 camaro
Engine: 305 t.b.i
mystery
i think i figured it out, the wiring harness is for a transmission with an electric vss and the transmission is set up for a cable vss. thankyou for the help. i dont think it is going to hurt anything if my cable vss is connected and the stray wire just hangs there. is it?
Re: mystery
Originally posted by kdubdizzle....i dont think it is going to hurt anything if my cable vss is connected and the stray wire just hangs there. is it?
You're TBI's VSS connector is supposed to connect to a by-pass. Someone might have discarded it when they sold you the engine and tranny, or maybe you accidentally tossed it when the swap was made...
Again, no biggie. Their plentiful...
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
the wires are hanging there because the camaro used a vss on the guage cluster and the firebird used it on the transmission
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have that exact connection hanging from the rear of the motor close to the drivers head. Its not connected either. I have always wondered what it went to and still dont know.
Car: 1986 Firebird
Engine: 2.8 V6
I think what Jproz is trying to say is: Firebirds with full gauges got the VSS in the tailshaft starting in '86. (Non-full-gauge Firebirds still had the VSS in the speedomter.) So it may be a Camaro vs Firebird factory-parts-bin thing, if Camaros & Firebirds used the same engine wiring harness. I forget when the Camaros got the tranny mounted VSS... wasn't it in 1988 or 89?
Just a wild guess!
Just a wild guess!
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
