T56 rebld - Need input shaft. Who makes a SFI bellhousing?
Old May 12, 2005 | 05:13 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
My tranny is hurting bad. The input shaft is out of wack by 20 thou and the output - 5-6 gear splines are worn. Looks like the previous owner accidentally threw it in reverse while rolling and the splines jumped. The input may have been dropped or possibly bent if the tranny was hanging all the weight on the shaft when removing.
I talk to Steve and D&D performance. Those guys are great, very helpful. Anyway, they have new mainshafts for 149 cause they pull them out of their new trannys when they convert them to the viper output setup. Just in case you were wondering, they do not recommend that expensive viper setup unless you break the stock one or you are running 9.40 or faster! Pleanty of guys they know running 9.90s on a stock LT1 T56!!
A new input is 299. Just wondering if I could find one cheaper. I already am $510 into the rebuild.
Second question is who makes a SFI approved bellhousing that will mount to my pre 1987 SBC. Also need a flywheel and clutch recommendation for a car that can pull 10.50s on motor.
My plan for now is to use the trans back and forth between the 83 and the 90 until I get extra dough to buy another trans.
Old Jul 12, 2005 | 10:01 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
The clutch I would go w/ the spec stage 5. I have one and it's actually easier to drive than the stage 4. The 5 is rated to 1000 ft lbs.
Old Sep 8, 2005 | 02:16 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Sorry to bring back, but what did you decide as far as the clutch/flywheel and bellhousing? Im trying to decide on what tranny i want to use my my 69 350 block with the EXT/balanced 383 crank.
Old Sep 11, 2005 | 02:02 AM
snm92rs's Avatar
Car: 1992 RS
Engine: 5.0 LO3
Transmission: A whacky A4
Check out McLeod Industries.
www.mcleodind.com
BlackphantomZ28
Apr 24, 2016 08:14 AM
86White_T/A305
Aug 17, 2015 12:16 AM
383backinblack
Aug 15, 2015 06:36 PM
sreZ28
Aug 14, 2015 07:48 PM
