tko 600 advice
Old May 14, 2005 | 11:32 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
tko 600 advice
my problem is basically that i live in canada
www.canada-wide-parts.com can get me a tko 600 for 2250 canadian before taxes and i dont have to pay shipping because i can drive to go pick it up.
The problem being the tko 600 they sell is meant for a 2nd gen camaro. Their advice was to use a muncie t-10 90 degree bellhousing and a mechanical linkage. What problems am i going to run into if i decide that i want to go this route?
The easy solution is just to order the tranny from www.5speedtransmissions.com (they are the people who sell fortes transmissions) thats designed for my car but thats gonna cost me a bunch extra.
Old May 14, 2005 | 02:34 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
you can buy a lakewood scatter shield that has the angled and non angled mounting holes, and also has provisions for stock hydraulics
Old May 14, 2005 | 03:08 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
lakewood part number 15020
1984-92 Camaro
Fits Camaro-small block and 90° V6 (Chevrolet) applications with hydraulic clutch linkage bracket and is drilled for 17° canted T-5 and standard GM Muncie/Borg-Warner T-10 transmissions.
But i was under the impression that you still need the custom bracket that fortes makes to use that bellhousing. Someone fill me in.
And if i decide to order the tko600 from www.5speedtransmissions.com will the stock t-5 bellhousing and flywheel work with the forte's modified tranny? Because i can probably get those used and get the flywheel resurfaced for less then buying the parts new.
Old May 15, 2005 | 04:18 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ttt, can someone please answer these questions.
Ive searched numerous times and already had a couple posts up but i am still confused.
Old May 16, 2005 | 09:45 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
can someone please answer these two simple questions
Old May 16, 2005 | 09:15 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
you guys dont wanna see me cry do you
all i wanna know is if i could use a stock t-5 flywheel and bellhousing with the fortes tko 600
Old May 16, 2005 | 10:27 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Why not ask the dealer, or Fortes? Or Tremec? Apparently not enough folks here have tried what you're doing.....
Old May 17, 2005 | 03:20 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Stock flywheel will be fine. Get it resurfaced only IF you are installing a new clutch with it.
Yes. As long as you use the trans adapter plate that comes with it.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
