Transgo Install problem
Old May 16, 2005 | 09:34 AM
QuickGlass's Avatar
I just installed a transgo shift kit in a 1987 corvette. The trans shifts very good. But now twice while driving on the highway, fluid started poring out from somewhere. It doesn't seem to leak at all when I drive around town or the trans is cold. I checked the fluid level and all is good.
I suspect the front pump seal is leaking, but why would it leak now? Can the increased pressure be causing this?
Old May 16, 2005 | 11:11 AM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
Check the T.V. cable and see if it is seated properly that same thing happened to me turned out to be the T.V. Cable seal.
Old May 16, 2005 | 11:00 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
My 700r4 that just blew was leaking. It was my TV cable. The bushing/gasket broke. Might want to check that.
Old May 17, 2005 | 09:56 AM
QuickGlass's Avatar
I removed the converter inspection cover, definitely coming from the front pump seal and definitely started leaking after installing transgo kit, not sure why.
Old Jun 2, 2005 | 05:46 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
could be you had a small leak and didnt notice it but since the shiftkit raises line pressure it may have made the leak bad enough to notice now.
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
