Trans fluid pressure gauge- how's this one?
Old May 16, 2005 | 10:11 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey guys, how's this for a trans fluid pressure gauge? Think it'll have what I need to hook up to my 700r4?
http://www.sjdiscounttools.com/ta34580.html
Also, when I tap into the case to check pressure, do I have to put sealant back on the plugs when I take the gauge off?
Oh- one more Question- I don't think I'd ever use this set to check engine oil pressure- but say that I did. Would I have to somehow flush that hose out before going between trans fluid to engine oil and back to trans fluid? Or would draining the hose be enough?
Old May 16, 2005 | 01:14 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
http://www.bowtieoverdrives.com/cata....php?ITEMID=51
0-300 PSI Pressure Gauge/w 7 foot hose
1/8 NPT 90 degree pipe fitting screws into pressure port on Custom Bowtie Overdrives temperature guage/sending unit Inline filter.
About $20 dollars more, but with a little more
Old May 16, 2005 | 06:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Who makes it? It's probably just $20 more because it includes a temp gauge and some kind of filter, which I don't need.
I won't be permanently mounting this; this is just for diagnostics only...
Old May 17, 2005 | 11:08 AM
Car: 85 Trans Am
I have this kit at my house, and its not made to be installed forever, its just for doing the pressures test while you are driving the car.
The temp gauge if you dont already have one is a very good thing to have. The filter is more of a thing if you just got it rebuilt, extra protection.
If you dont need those things then just get that kit you linked, it looks pretty well put together
maroe624
Apr 16, 2017 08:29 AM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
