2.77's to 3.23's
Old May 16, 2005 | 05:57 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
2.77's to 3.23's
now that i know what my other rear end is, what im I gaining in puttin 3.23's? Will it be better than my stock 2.77's? Both of them are posi-limited slip
Old May 16, 2005 | 09:36 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Well 2.77's are 9 bolt ratio and 3.23 are 10 bolt ratio. What you want is to either have 2.73 and go to 3.23 or 2.77 and go to 3.27.
For acceleration the 3.23 would be better in most third gens, however 3.42 would probably be best although the posi condition does play a huge factor.
But if you were looking at strength compared to the 2.77 and the 3.23, the 2.77 will be stronger just for the simple fact that it is a 9 bolt.
Old May 17, 2005 | 06:14 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Yeah, but my 9 bolt is shot, and when i try to launch one tires spins but the other one just stays there, and it makes a whinning noise when accelerating, the only disadvantage of the 10 bolt that i got is that its drum brakes
Old May 17, 2005 | 06:29 PM
Car: 91 Camaro RS
Those PBR brakes are nice too and the 10 bolt being weaker is another setback.
Old May 17, 2005 | 07:15 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
From a performance point of view though, how much of a gain would you receive from the swap to the 3.23s in the quarter?
Old May 17, 2005 | 07:43 PM
Car: 91 Camaro RS
Maybe 2 tenths depending on how fast you are now and condition of posi and traction. 2.77 to 3.23 isn't that large of a jump. 3.42 between 3 and 4 teeths.
Old May 17, 2005 | 11:15 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
but i thought I couldnt put no more than 3.08's on a BW rear end? and the 10 bolt seems in good shape, no leaks, i move the drum and they move at the same time. But on the 10 bolt cant i replace the gears and go 3.42's?
Old May 18, 2005 | 08:59 AM
Car: 91 Camaro RS
You can replace the gears on either, you just have to have matching gears and carrier in the same series. Such as 3.45 gears in the 9 bolt.
Old May 18, 2005 | 09:41 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
So u think i should throw on 3.42's on it?
Old May 22, 2005 | 11:30 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
if it's a 10 bolt why not.
Old May 25, 2005 | 07:13 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Yeah i tired getting gears for my 9 bolt but this is what they told me at thunderracing.com
"If you have a 2.77 gear then you should have a 9 bolt. If it is a 10 bolt cover, then the gear would be a 2.73. For the 10 bolts a 3.42 would be the gear of choice. Unforunately we don't offer any gears for the 9 bolt rears.
Thanks,
David Tuschhoff"
deracer
Apr 11, 2016 12:04 AM
KO1
16
Oct 15, 2015 05:00 PM
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
