bleeding slave cylinder
Old May 23, 2005 | 06:59 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i was wondering what is the right way to bleed the slave cylinder. i bought an aftermarket one (it has a set screw in it to bleed) all i did was cracked open the set screw and let it gravity bleed while i kept the resevior filled but how do you actually bleed it. i just put a new clutch in it and it engages about 1" off the floor. no pedel whatsoever. any help would be great. thanks
Old Mar 16, 2010 | 11:31 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Re: bleeding slave cylinder
hi i got the same set-up ,,new clutch-flywheel-pressure plate kit ,,,got a new complete after market clutch slave assembly...tried to bleed it ,,pedal is rather soft..was wondering if i should keep bleeding too....and if i am doing it right ...
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
