New transmission/tv cable issue
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Hello all,
Have a newly rebuilt transmission from a very reputable shop in the area. bought a brand new tv cable from napa and have double checked to make sure its the right one. Problem is the tv cable has a full inch of slack as opposed to the 1/8" max its supposed to. even at full throttle, it doesn't cause the auto adjuster to click at all. I have also checked and it is attached to the spring in the trans as it should be.
This transmission hasn't been driven since the rebuild (filled and run but not in gear), is this something that will be pulled back in once all the valves and stuff start working? I spent a good chunk of change getting this trans built strong so I don't want to smoke it because of a 20 dollar part.
thanks in advance for the help,
Jason
Jason
Engine: 5.7L w/hsr
Re: New transmission/tv cable issue
i've been searching for days and have found nothing. if it will help here is a photo.. i don't know why it won't retract fully but its definitely the right part number, and definitely attached correctly to the spring:
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Engine: 5.1 4bbl
if you unhook the cable and apply tension on it buy pulling it gently do you feel some tension? or better said resistance?
Engine: 5.1 4bbl
you might have to get a GM made cable then... you won't be the first that has had problems with an aftermarket cable...
or the only other option I see is buying a lock, don't know what they're called you would have to cut the end of the cable, after the throttle linkage and then pull on the cable so it's flush with WOT...
TheTraut88
Sep 7, 2015 05:22 PM
