racing question
Old May 29, 2005 | 11:28 PM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
racing question
im about to take my gta to the trakc to get its new base line and i was wondering if i should drag it in Drive or Overdrive?? is a rebuilt 700r4 behind a gasket matched 350 and 3.45 gears in da rear....when i last took it to the strip, i left it in overdrive and the fastest i went was 15.1 and that was with stock size intake, and valve seals leaking bad......i am hoping for mid 14's now but i am unsure...i wasnt sure if it would be a big diff. with drive and overdrive, just thought if i left it in drive it would just be dieing at end of the track for overdrive...i know its a noob question, but i have been hearing things from leave it in drive, shift it manually, or leave it in overdrive...
any helop would be nice
dave
Old May 29, 2005 | 11:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There shouldn't be any difference. You don't want to get into OD anyway. It's a weak small gear. If you do get into OD in the 1/4 mile, gearing, shift rpm or tire size is all wrong. You should cross the finish line in high gear (1:1) at or just before your shift point.
Since the transmission is shifting on it's own, you're not going to see any change in ET if it's in D or OD.
Old May 30, 2005 | 12:21 AM
thnx man i figured i would mostly leave it in drive and if it gets to were its got no power then i will throw it into overdrive...i just questiond it cuz i raced my buddies ls1 and hit end of power band pretty qick...we'll see at the track...thanx again
dave
Old May 30, 2005 | 12:27 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
you cant **** into OD in WOT. so get off gas when you do it.if you even can do that.
wild1
Aug 27, 2015 09:01 AM
theurge
Aug 21, 2015 12:46 PM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
