e-brake cables for a 3rd gen with 4th gen rearend...
Old Jun 1, 2005 | 09:38 PM
skatnkidd's Avatar
Car: 91 Z28
Engine: 305(LB9) 256hp/332tq @ the whls
Transmission: 700-R4
Messed up the topic heading so everyone was probably looking at it like I was crazy. Anyway,I posted a topic about swapping a rearend from a 4th to a 3rd gen. Unfortunetally, I didn't think about mentioning that I have drum brakes in the rear. I looked at a previous post and it mentioned that the brake cables would not work if out of an LT1, which is true(found out first hand). I called GM and they said two styles are made but one is discontinued. The difference is in length but I'm not sure which one is correct. They measured in mimimeters and only vary about 20mm from each other. I'd buy the one they have except its $35 with is a lot to pay for a non-returnable item if it doesn't work. Any help would be great!!
Old Jun 3, 2005 | 10:22 PM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
I bought em and they work just fine. A little mod done to the mounts up in the "tunnel" though. I moved them b/c the litlle metal clip thingys on the cable are in a different location. Nothing huge but I now have an e brake.
Frozer!!!
Jan 19, 2024 04:55 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
jbd1969
Aug 17, 2015 07:06 PM
