I'm Getting Really Pissed Off
Old Jun 2, 2005 | 04:52 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
The transmission shift cable keeps popping out of that stupid lame *** bracket under the car almost every day. I've tried putting screws behind the ears, paperclips, you name it. I'm getting so frustrated because this should be the least of my problems BUT IT'S NOT BECAUSE IT PREVENTS ME FROM SHIFTING WHEN IT HAPPENS. It takes about 15 minutes to fix AND IT'S GETTING OLD FAST
What do I do?
Old Jun 2, 2005 | 05:02 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Okay, now it's ****ing broken. Brand ****ing new shift cable BROKEN. Way to go, $45 and 4 days to order it. I'm so pissed off right now. WHOSE DUMBASS IDEA WAS IT TO PUT PLASTIC WHERE MACHINERY OPERATES ANYWAY????
Old Jun 2, 2005 | 05:18 PM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
plastic is
Old Jun 2, 2005 | 06:05 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I'm seeing of Lokar makes one made of METAL
Old Jun 2, 2005 | 06:29 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Here's a picture of the transmission linkage. The new one is already broken in two spots after LESS THAN TWO DAYS. The old one is fine on this half.
Old Jun 2, 2005 | 06:32 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Here's the shifter linkage. I had to replace the old one because it broke off from here. I had to literally hold the cable in place when I was shifting it "forward" or it would just move freely and obviously not shift. The new cable is fine on this end, but it fought with me when I was trying to put it in.
Old Jun 3, 2005 | 02:04 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you've been thinking of upgrading to a B&M Megashifter, now would be a great time.. You'll run into none of these problems with a B&M cable and bracket (all metal )..
Old Jun 3, 2005 | 05:55 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I wish I could afford one right now. Then again, better than wasting $45 on a POS plastic.
Old Jun 4, 2005 | 10:48 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
looks like an after market one? I went through a few from auto-zone on a friends car. they did not make those ears right and it would pop out and if you even heated them up to bend them out it would break as well. long story short we used zip ties behind the ears untill a gm one was ordered. fit right in never had a problem, took the autozone one back
85 Jimmy
Sep 30, 2015 07:56 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
djmarch
Aug 19, 2015 12:07 PM
legendaryhero7
Aug 12, 2015 06:19 PM
91FastBird60kmiles
Nov 19, 2000 10:03 PM
