T-5 swap, clutch not disengaging
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
My clutch won’t disengage, I replaced the master and slave cylinder. I checked the throw out bearing and it’s in there correctly. the petal feels fine and the hydraulics move but it seems like it doesn’t move far enough because when I push in the petal and I pry the fork, the clutch will disengage and the slave cylinder will hold it there but when I push it in again it wont disengage. I have tried putting a longer rod in the slave cylinder but it just dose the same thing. Please help I have been stuck on this for a while so any ideas will help.
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I recently did the clutch in my car and I had to bleed the slave cyclinder I am sure you did this. When I was done it still felt like a sponge but when i got the car goinng it was fine , I was sure it was wrong . U mite want to check and see if the fork is seated properly in the bell houseing to .I do not know if you did the clutch but maybe somethings wrong in there,I do not know if any of that will efect your problem. I sure u will find the ansewr on this site . I am new hear too good luck.
rsrmoore
Aug 7, 2015 08:44 PM
